How to change scheduler's configuration through script
  • March 15, 2017
  • 4 replies
  • 3765 views
Hi guys,
I want to change scheduler's configuration through a script called in a subscription event.
For scheduler entity find only DisableScheduler and EnableScheduler method.
Is it possible to change scheduler's configuration at "runtime"?
Thank's to all
    Best answer by flucciarini
    I find the problem
    correct code below
    var sch = Things["LightSwitchOn"];
    var params = {
      tableName: "Settings" /* STRING */
    var ext = sch.GetConfigurationTable(params);
    var x = ext.getRow(0);
    x.SetStringValue("schedule", "0 " + cronDate.getMinutes() + " " + cronDate.getHours() + " * * ? *");
    x.SetBooleanValue("enabled", true);
    x.SetStringValue("runAsUser", "Administrator");
    var paramsSet = {
      configurationTable: ext /* INFOTABLE */,
      persistent: true /* BOOLEAN */,
    // no return
    sch.SetConfigurationTable(paramsSet);
    sch.EnableThing();
    logger.info("Controllo configurazione restart LightSwitchOn");
    sch.RestartThing();
    Thanks Ankit for java solution
    Hi Fabrizio Lucciarini​,
    We have option to set the Configuration by using the service SetConfigurationTable.
    After running the service you will have to call RestartThing Service to run it with the new configuration.
    I had written following Java Code to update the configuration sometime back. You can write a similar code in JavaScript.
    Thing sch = ThingUtilities.findThing("SchedulerXXX");
            InfoTable ext = sch.getConfigurationTable("Settings");
            ValueCollection x = ext.getRow(0);
            x.SetStringValue("schedule", "0/10 * * * * ? *");
            sch.SetConfigurationTable("Settings", ext, true);
            sch.EnableThing();
            sch.RestartThing();
    I hope it helps.
    I write in javascript the code below
    var ext = sch.getConfigurationTable("Settings");
    sch.EnableThing();
    sch.RestartThing();
    but I get the following error
    TypeError: Cannot find function getConfigurationTable in object com.thingworx.things.scheduler.SchedulerThing@36edb26b. (ScheduledEvent#18)
    flucciarini1-VisitorAuthorAnswer
    I find the problem
    correct code below
    var params = {
    var paramsSet = {
    // no return
    sch.EnableThing();
    sch.RestartThing();
