How to create and show a region on google map widget
  • December 30, 2016
  • 6 replies
  • 4831 views
I am quite sure I can find an example somewhere in the support but I looked for without success.
I want to create an area by clicking locations on google map widget and that this area is visible on the map.
I've seen there is the possibility to bind a region but maybe I'm doing something wrong.
I have a ThingTemplate with 10 things, each thing has a location property, I want those 10 locations set a region.
If I load the GetImplementingThingsWithData service and bind AllData to RegionData, I can't see my region.
Another thing I would like to do is make the user define a new region by clicking a certain number of points on the map which will set the perimeter of the area.
Is there anyone who could explain me this? Or also could give me a link with a document I can read?
Best answer by aduarte
For your first question, take a look at this: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS225480
I hope that this can help you.
aduarte1-VisitorAnswer
fmanniti1-VisitorAuthor
Thank you very much. It's what I needed.
