how to export all the entities of thingworx in one file, which are tagged under one model tag?
  • August 30, 2016
  • 2002 views
all the entities which are created under same model tag, how to export them all as a single file so that one application can be easily exported from one Thingworx instance to another
Best answer by CarlesColl
Hi
From Composer:
  • Import/Export > To File > "Select desired Model Tag" > Export ( you can export it either on Binary format or XML ).
Best Regards,
Hi
From Composer:
Best Regards,
