How to handle java null pointer exceptions
  • May 18, 2017
  • 9 replies
  • 6088 views
Hey There,
I was working on this very simple service that I wrote for ThingShapes.
All I am doing is "Updating a Thing's Property". However, I keep getting java.lang.NullPointerException Cause: Null,
my Service on the Thing is following:
if(Contact){
Things[uuid].Contact = Contact;
if(Contact_Phone){
Things[uuid].Contact_Phone = Contact_Phone;
if(MyName){
Things[uuid].MyName = MyName;
if(phyLocation){
Things[uuid].phyLocation = phyLocation;
if(freq){
Things[uuid].freq = freq;
I am not sure what I am doing wrong.
20-Turquoise
May 18, 2017
Without looking at your code first, what are the input and output types specified for the service?
mbereket1-VisitorAuthor
No Outputs, all string inputs
you can put few console.log() to check if any prop values are getting as null.
Also you can check the spell of Propery names if those are correct.
20-Turquoise
May 19, 2017
Try putting a space after the "if"s.
Tried but didn't change the result.
20-Turquoise
May 19, 2017
I've actually just tried running your service and it works. Could you please export your entity and email it to me to posipova@ptc.com ? I will check to see if everything was saved/declared properly.
