How to make Y Axis intervals dynamic for Label Chart
  • August 8, 2017
  • 2 replies
  • 1777 views
Hi Team,
I am facing issues with Label chart as the Y Axis.
When I fix the interval to 10, then I getting below graph and when I made it decimal the intervals are not uniform.
Thingworx version 7.1.2.
Hello, Plaban Patra.
I'm looking for documentation on this; I found the Help Center entry for the Range Chart.
http://support.ptc.com/cs/help/thingworx_hc/thingworx_6.0_hc/index.jspx?id=thingworx040442&action=show
Do you have a variable
YAxisAutoscale: description: Automatically scale the vertical axis baseType: BOOLEANdefaultValue: true
And is it set to true?
-- Craig A.
plaban1-VisitorAuthor
Hi Craig,
Yes, that is marked true.
