How to remove the duplicate entries (alternate entries) from a grid which displays an infotable.
  • August 1, 2016
  • 11 replies
  • 5441 views
in the alert history table each alert is displayed twice as an alternate entry.
Best answer by ibanham
Use QueryStreamEntries with data rather than Get....
That's strange, did you tried to query for Alerts directly with Test button on the composer to see if maybe you have the Data doubled and it's not a Grid bug.
The Alert History table is basically a Stream that records Alerts and what happened to them. It's normal to have multiple entries for a single alert.
You get an entry when the Alert is triggered, and another when it is reset. You will also get an entry when the Alert is acknowledged.
psaxena1-VisitorAuthor
I am displaying the alert history table in a grid in a mashup, so can I eliminate dulicate entries in a grid? Because the difference is in the decimal value of seconds in the timestamp.
Look at the Alert History screen under the Monitoring menu - the eventName column should give you something to filter by.
A new alert has an event name of "Alert", when the alert re-sets the event name is "AlertReset".
