How to retrieve name of a thing by specifying ID and accessing its properties
  • May 19, 2017
  • 8 replies
  • 4593 views
Good morning!
I have created  a few Things which inherit the properties from a ThingTemplate which holds a property Identifier string and another property for temperature.
In addition, I have created a helper thing to create a static service. This service gets two inputs: an identifier string and the temperature.
The service should retrieve the name of the thing which holds the same identifier string and should update the temperature property.
I have already found a function which seems to be made for that. It is called GetThingNameForIdentifier(identifier) and returns a THINGNAME.
But I haven't found anything on the internet on how to use this datatype and how to access the thing's properties.
Any suggestions?
Thank you in advance for your help
Theresa~
    Best answer by ankigupta
    Hi Theresa Lichtenberger​
    Please try:
    Things[THINGNAME].temperature= temperature;
    ankigupta5-Regular MemberAnswer
    Please try:
    hi Ankit Gupta​,
    and how do I use the GetThingnameByIdentifier(identifier) function?
    Is it like this or am I doing anything wrong:
    var params = {
    identifier: ID/* STRING: ID is the property Name of the Thing */
    // result: THINGNAME
    var thingname = Resources["EntityServices"].GetThingNameForIdentifier(params);
    Things[thingname].temperature= temperature;
    thank you again for your help!
    because if I test my service I get a the following error:
    TypeError: Cannot set property "temperature" of null to "40"
