How to start a service from C SDK?
  • June 25, 2015
  • 2 replies
  • 1752 views
I would like to call a service of my thing on Thingworx from my C program created with the model C SDK. I already tried to use the function "twApi_InvokeService" but it doesn't work. If someone can give me more explanations about this function.
I am using Thingworx 6.0.1 and the C SDK
Anthony
    Best answer by christianb1
    Have you checked the debug output of the c application?
    Here is a simple example how to call a SteamSensors service named "CountDataCollectionTasks"
    // in void dataCollectionTask of SteamSensor example
    int res = 0;
    twInfoTable * values = NULL;
    twInfoTable * result = NULL;
    values = twInfoTable_Create(twDataShape_Create(twDataShapeEntry_Create("values", NULL, TW_INFOTABLE)));
    res = twApi_InvokeService(TW_THING, thingName, "CountDataCollectionTasks", values, &result, -1, FALSE);
    TW_LOG(TW_INFO, "invokeService: %d", res);
    // we are responsible to clean the result
    twInfoTable_Delete(values);
    twInfoTable_Delete(result);
    in api/twApi.c is an example how the twApi_PushProperties invokes the "UpdateSubscribedPropertyValues" service of the thing.
    Do not forget to create the service in TWX at your Thing.
    int res = 0;
    anthony11-VisitorAuthor
    Thank you, it works fine now .
