I have to edit particular node in the xml file node will be user input how can I do it???
  • June 7, 2017
  • 2 replies
  • 1741 views
suppose I have following xml
<edge>
<processing>
<threads_count>99</threads_count>
<queue_limit>1233</queue_limit>
</processing>
<gui>
<port>9901</port>
</gui>
<edge>
I can edit processing data like this xmlFile.*::processing but processing will be user input it can be either processing/ gui hw to use variable data in that code ???
Best answer by PaiChung
Have you tried [YourVariableHere] or (YourVariableHere) to represent the node?
PaiChung22-Sapphire IAnswer
22-Sapphire I
June 7, 2017
Hi ...
you could create a mashup, with some textfields and pass on its contents to a service which is using numbers and input parameters (e.g. n1 & n2).
The service then manipulates the xml structure and you can use it with its values changed afterwards.
I've tried the following code which is replacing the numbers with the numbers I specify in the n1 & n2 input parameter:
I hope that helps...
Cheers,
Michael
// read xml file
var params = {
ignoreSSLErrors: true /* BOOLEAN */,
url: "<urlToMyXmlFile>" /* STRING */,
// get xml structure
var xmlVar = Resources["ContentLoaderFunctions"].GetXML(params);
// change values
xmlVar.*::processing.threads_count = n1;
xmlVar.*::processing.queue_limit = n2;
// return xml
var result = xmlVar.*::processing
