I want to append image to string/text while writing service
  • March 3, 2017
  • 7 replies
  • 3389 views
Please check below service code:
var connections;
if (filter == "blank") {
  connections = Networks['FlowServeNetwork'].GetNetworkConnectionsWithTemplate();
} else {
  var params = {
  start : filter
  connections = Networks['FlowServeNetwork'].GetSubNetworkConnectionsWithTemplate(params);
var params = {
  dataShapeName : "FlowserveTreeNetwork",
  infoTableName : "AssetHierarchy"
// CreateInfoTableFromDataShape(dataShapeName:STRING, infoTableName:STRING("")):INFOTABLE
var assets = Resources['InfoTableFunctions'].CreateInfoTableFromDataShape(params);
var connection;
for each(connection in connections.rows) {
  var data = new Object();
  data.to = connection.to;
  data.from = connection.from;
  data.connectionType = connection.connectionType;
  var thing = Things[connection.to];
  var alert = MediaEntities["YellowAlert"].GetImage();
    data.description = thing.description + " " + alert; //appending alert icon with description
    assets.AddRow(data);
var result = MediaEntities["YellowAlert"].GetImage();
am unable to append image with text. I have tried keeping description type as text,blob,string in datashape.
am getting error as "[context: com.thingworx.webservices.context.HttpExecutionContext@2ea80460][message: Execution error in service script [FlowserveNetworkServices testImage] : Unable To Convert From [B to INFOTABLE]"
Best answer by posipova
You could try HTML, I know it worked for a text + image for a grid cell (from an infotable);
20-Turquoise
March 3, 2017
You cannot add an image to a description, description has to be a string type. What is your use case?
nbhagtani1-VisitorAuthor
Is there any other type i can keep which will accept String and Image?
I have to display description (string + image) on tree label. Image will be dynamic attached to some description and that description need to be displayed on tree.
posipova20-TurquoiseAnswer
20-Turquoise
March 3, 2017
22-Sapphire I
March 3, 2017
I would use an infotable so one column carries the text the other the image.
If you are using this in a mashup, you can use state based formatting or use a composite of a value display with image display
I have kept description and image in different column in infotable. But i don't know how to display text+image on tree(text and image will change on logic).
Yes i have to show data in mashup and i have tried using state based formatting for tree but i am able to display icon then text and i need text then icon.
