I want to retrive a data from Thingworx platform to java SDK. Can anyone please suggest me how to do it. Please do the needfull.
  • May 18, 2017
  • 6 replies
  • 4752 views
    Best answer by vr-6
    import java.io.BufferedReader;
    import java.io.DataOutputStream;
    import java.io.InputStreamReader;
    import java.net.HttpURLConnection;
    import java.net.URL;
    import javax.net.ssl.HttpsURLConnection;
    public class HttpURLConnectionExample {
        private final String USER_AGENT = "Mozilla/5.0";
        public static void main(String[] args) throws Exception {
            HttpURLConnectionExample http = new HttpURLConnectionExample();
            System.out.println("Testing 1 - Send Http GET request");
            http.sendGet();
        // HTTP GET request
        private void sendGet() throws Exception {
            String url = "http://localhost:9090/Thingworx/Things/Thingname/Properties?appKey=9d60cdb1-3761-4c85-8fa9-3485b71e6f97";
            URL obj = new URL(url);
            HttpURLConnection con = (HttpURLConnection) obj.openConnection();
            // optional default is GET
            con.setRequestMethod("GET");
            //add request header
            con.setRequestProperty("User-Agent", USER_AGENT);
                    con.setRequestProperty("Accept", "application/json");
            int responseCode = con.getResponseCode();
            System.out.println("\nSending 'GET' request to URL : " + url);
            System.out.println("Response Code : " + responseCode);
            BufferedReader in = new BufferedReader(
                    new InputStreamReader(con.getInputStream()));
            String inputLine;
            StringBuffer response = new StringBuffer();
            while ((inputLine = in.readLine()) != null) {
                response.append(inputLine);
            in.close();
            //print result
            System.out.println(response.toString());
    You can use above code to print properties in java. Response will be in JSON format.
    20-Turquoise
    May 18, 2017
    Depends on what your end goals are/what you are trying to achieve.
    There are multiple ways:
    • using REST API of the Plattform, pull data from the platform - PTC - helpcenter - it is very straightforward and can be tested with every Browser.
    • using PropertySetters in SDK; Edge helpcenter PTC
    • using services triggerd in the plattform sending data to the device (PUSH)
    You can use GET method to retrieve current property value of thing
    OkHttpClient client = new OkHttpClient();
    Request request = new Request.Builder()
      .url("http://localhost:9090/Thingworx/Things/ThingName/Properties")
      .get()
      .addHeader("appKey", "8")
      .addHeader("content-type", "application/json")
      .addHeader("accept", "application/json")
      .addHeader("cache-control", "no-cache")
      .build();
    Response response = client.newCall(request).execute();
    To retrieve property history you need to use POST method
    MediaType mediaType = MediaType.parse("application/json");
    RequestBody body = RequestBody.create(mediaType, "{\n\t\"maxItems\": 500,\n\t\"startDate\":1495119100,\n\t\"endDate\":1495119875,\n\t\"oldestFirst\":true\n}"); // Start Date and End Date UNIX timeformat
      .url("http://localhost:9090/Thingworx/Things/ThingName/Services/QueryPropertyHistory?Content-Type=application%2Fjson")
      .post(body)
      .addHeader("appKey", "ccccccc")
      .build();
    Replace appKey and ThingName
    gd111-VisitorAuthor
    Thank you for your response.
    I have tried with GET method. In browser i am getting the properties of the particular thing but when i am invoking URL in code , not able to retrive the properties. I need to print the properties in my java code. How can i get ?? Any idea?
    vr-61-VisitorAnswer
            http.sendGet();
        // HTTP GET request
            String inputLine;
            in.close();
            //print result
    gd111-VisitorAuthor
    One more doubt i have, I have created a Mashup with one textbox and button. I will enter value in textbox and i will submit the button. I want get the entered value in JavaSDK. Any idea? please ASAP.
    Thank you
