Importing Read Only Entities
  • August 9, 2016
  • 2 replies
  • 1391 views
Hi Guys
Apologies if this one has already been asked, I can't find a relevant thread.
Does anyone know how to import Entities which are Read Only and ensure that no one can see the code or mechanics of the Entities when importing to a different ThingWorx instance? And also makes the majority of the XML invisible (services, events etc)?
Many Thanks
Ashley
Best answer by asinclair
Ashley,
If you import an entity into a Thingworx Java extension, built it, and then import the extension into Thingworx, the imported entities will be read only as you describe.
-Andy
asinclair1-VisitorAnswer
Ashley,
-Andy
ashleyg1-VisitorAuthor
Thanks Andy, much appreciated.
