Infotable sort function case sensitive
  • May 29, 2017
  • 2746 views
Infotable sort function returns case sensitive result when sorted on column which has string data type.
var params = { sortColumn: "column1", t: "myinfotable", ascending: true };
var result = Resources["InfoTableFunctions"].Sort(params);
Is there a way to sort infotable keeping sort type case insensitive ? or work around ?
Thingworx version - Thingworx v 7.2.6-b76
Best answer by CarlesColl
Create a new column with Derive snippet where you set it to fieldName.toLowerCase() and sort by this column.
