Is it possible to use pre-defined views (like in SQL) for TWX Streams?
I have a Stream storing a lot of history data of an entity. The data is delivered in a 10 minute frequence and I am visualizing it in a Time Series widget on a dashboard. For a day based view the time series looks fine - If I want to look at a year based view there a far too many data entries and the time series graph is unuseable - moreover it needs a lot of time and computing power to load the data.
SQL databases bring the possibilities to query pre-defined views for showing aggregated data on hour/day/... basis. Does TWX bring a similar possibility? If not what would be the best practice to implement such a kind of service?
Thank You and regards,
Marco
