Line Chart X-Axis Labels
  • September 29, 2017
  • 2940 views
Does anyone know if its possible to set the X-axis label on the Line Chart extension? I cant seem to find the option in the widget setup to allow me to do it.
David.
    Best answer by posipova
    It is not possible in the OutOfTheBox widget, however, you may look into customizing it yourself. Please fine the documentation on custom development attached. Make sure to keep a copy for backup purposes if doing the modification to the existing widget. You may also use Global Services - they can develop the solution for you for a fee. If you do wish to go with the Global Services team, you may contact your sales representative.
    posipova20-TurquoiseAnswer
    20-Turquoise
    September 29, 2017
