Mashup navigation from Master
  • June 5, 2017
  • 5 replies
  • 2932 views
Hi Guys,
I have one hing that bugs me. When I am viewing a master containing pre.configured menu, after I press some Menu Item all I can see is just a blank page. MashupName parameter is not attached to URL.
When I am viewing some mashup which uses this Master layout, navigation works fine.
Idea is to use Master as "Home mashup" for each user not the mashup it self. I though that that is why there is a "default" in menu item configuration.
I am on 7.3.4
Any ideas?
Tomas
Best answer by posipova
Ah, as I mentioned above-  this works per design. We expect users to start with the mashup rather than the master (think of it as a header piece). I apologize for the inconvenience this might be causing you.
20-Turquoise
June 5, 2017
Just to clarify, you are viewing the master originally and not the mashup with the master attached, correct? This works per design. The mashup itself to be used by default and the master would be the header attached, whetehr menu driven or not.
tcoufal1-VisitorAuthor
Yes I am viewing the Master not the Mashup.
I can see my Master design (no pun intended) and menu items, but when I click on it i can see is blank page.
here is url schema when viewing master
https://SERVER/Thingworx/Runtime/index.html#master=MY_MASTER&mashup=
clicking on menu link will not append mashup name as url paramater
Viewing some mashup which uses my Master works as expected.
posipova20-TurquoiseAnswer
20-Turquoise
June 5, 2017
