Menu Style Image
  • December 1, 2017
  • 3 replies
  • 2494 views
Is there a way to apply a background style image to a menu element? I've tried including an image on one of the menu styles but it doesn't appear to load it. I've seen other examples of people doing this in mashups and I'd like to try and understand how they're doing it.
David.
Best answer by dkeeley
Hi Sushant,
I contacted support and was told it was a bug. I've found a work around using the frame layout extension. Its not ideal with it will work for now.
David.
Hi David, are you still having this issue? If yes, could you please share some comments on how and what was your attempt towards this use case? When you say it doesn't appear to load does it highlight any error (in the UI or the application log of ThingWorx?)
If you can share your approach I could try check that.
dkeeley1-VisitorAuthorAnswer
Hi Sushant,
David.
Thanks David for reverting. Adding the article here for other's reference The image set in a style is not rendered as background in the menu, in ThingWorx
