Not able to connect to thingworx via Java sdk extension
  • February 8, 2017
  • 1585 views
i have one java program and i am trying to connect to thingworx through java sdk extension.
i have used below code:
ClientConfigurator config = new ClientConfigurator ();
config.seturi();
config.setappKey();
config.ignoresslerrors(true);
But not able to connect to thingworx. its giving Timeout exception
Best answer by dupatel
Kedar Borkar​
You will have to pass valid argument with methods as below -
config.setUri("ws://10.196.110.229:8080/Thingworx/WS");
config.setAppKey("800d296f-1563-4d5f-bd5e-4ff23f959eca");
config.ignoreSSLErrors(true);
Note: Do not put the same details as it will not work and should be according to your environment.
-Durgesh
dupatel5-Regular MemberAnswer
Kedar Borkar​
-Durgesh
