On clicking of the button i want to add a textbox dynamically. Whenever i click that button a new text box should be placed automatically
  • March 7, 2016
  • 12 replies
  • 4950 views
Whenever I am clicking on a button a new text box should be there on the mashup
You should use a Repeater.
March 7, 2016
HI Carles,
But how to use the repeater widget, as in repeater widget we give limitations, how much time it should repeat.
Hi, Repeater Widget doesn't have limitations, you should have a service on Server Side where you query for the content to show on the rows, and another service to add a new row.
March 8, 2016
Hi Carles,
Normal java script coding will work here to add a new row.
March 8, 2016
We are not able to add the new row upon clicking of a button.
we are only able to add only one text box in one row.
What it should ideally do like that when i click on the button it should add a new text box. Please help us with the code.
Aditya Kumar
March 8, 2016
We are using the repeater widget now.
Aditya Kumar
  1. Build a mashup with a repeater. Let's call it ParentMashup
  2. Build another mashup with a Textbox, that Mashup it's the one that you will repeat on the repeater. Let's call it RowMashup, which has a parameter called id, and another called text
  3. Build a service which adds a Row to a an infotable or datatable with, this row will record the value of the TextBox. Let's call it AddTextBox with a parameter "Text" with the desired text on the textbox.
  4. Build another service which returns the rows for this Infotable/Datatable. Let's call it GetRows
  5. Bind del result of the GetRows to the Repeater on ParentMashup, now you just need to select the corresponding parameters for RowMashup, your are done.
