Organization Login Image
  • July 15, 2016
  • 2 replies
  • 1639 views
Hello All,
Is there anyway to access an organizations login image via a service?  I would like to give the user the option to set their own login image, but I can't seem to find a service or property that I can access the image from  Thanks!
Best answer by CarlesColl
Hi Braian,
Not out of the box with a Snippet.
But you can go to the Composer, activate Developer View on Chrome, and look the REST API Calls which does the composer and replicate it, easy to say not that easy to replicate
Best Regards,
Hi Braian,
Best Regards,
Brian, just to add to Carles's reply, you can only access (get) the existing image. The call used for that is - localhost/Thingworx/OrganizationLogoViewer/Name_Of_Org
