Output type for SQL Insert
  • March 16, 2016
  • 1791 views
I've created an SQL query service and added insert statement.
Though the insert statement successfully runs, I get "Unable to Invoke Service TestSQLInsert on MyDBThing : null".
The default Output type is INFOTABLE. Even after changing this output type to Long or anything, I get the same error.
What is the correct output type I should use? Is it right to have INSERT/UPDATE statements in SQL Query service? If not what is the approach I should use for writing INSERT/UPDATE statements.
Regards
Arunkumar D
Best answer by qngo
I think it's a SQL Command rather than a SQL Query. Then the Output type could be a number.
Quang-Dung
qngo1-VisitorAnswer
Quang-Dung
