Persistence of Thing Properties
Hi.
I have an issue with my understanding of persistence of properties. I have defined properties for several different things as being persistent. Nevertheless, after a reboot of the OS running the TWX platform, the values of those properties get vanished. My understanding is, that this shouldn't be - otherwise why should I mark something to be persistent? Or do I understand the implementation of the persistence not correct?
This happened with 5.1 and 5.3.
Edit
: I have the "feeling" that if a property was defined on shape or template level, the value on for individual thing persists. But if the property was defined on the thing level, that the value gets lost. Could it be a bug?Thanks.
Rayed
