Problem while installing ThingWorx for the first time
  • November 18, 2015
  • 4 replies
  • 2509 views
Seeing following error in Tomcat stderr log file (tomcat8-stderr.2015-11-18.log) while trying to bring up Tomcat app after deployment. Looks like something to do with datastore. Any idea what I may be doing wrong?
18-Nov-2015 07:47:32.618 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8070"]
18-Nov-2015 07:47:32.623 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-7009"]
18-Nov-2015 07:47:32.624 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 2217 ms
18-Nov-2015 09:00:03.620 INFO [http-nio-8070-exec-5] org.apache.catalina.core.StandardContext.reload Reloading Context with name [/Thingworx] has started
18-Nov-2015 09:00:03.651 SEVERE [http-nio-8070-exec-5] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [Thingworx] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@231d3916]) and a value of type [java.util.Stack] (value [[SuperUser:User]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
18-Nov-2015 09:00:05.117 INFO [http-nio-8070-exec-5] org.apache.catalina.core.StandardContext.reload Reloading Context with name [/Thingworx] is completed
ource@361fb98f' was successfully initialized, but failed to start. Please see attached cause exception.
at org.neo4j.kernel.lifecycle.LifeSupport$LifecycleInstance.start(LifeSupport.java:513)
at org.neo4j.kernel.lifecycle.LifeSupport.start(LifeSupport.java:115)
at org.neo4j.kernel.impl.transaction.XaDataSourceManager.start(XaDataSourceManager.java:164)
at org.neo4j.kernel.lifecycle.LifeSupport$LifecycleInstance.start(LifeSupport.java:507)
... 22 more
Caused by: org.neo4j.kernel.impl.storemigration.StoreUpgrader$UpgradingStoreVersionNotFoundException: 'neostore.nodestore.db' does not contain a store version, please ensure that the original database was shut down in a clean state.
at org.neo4j.kernel.impl.storemigration.UpgradableDatabase.checkUpgradeable(UpgradableDatabase.java:78)
at org.neo4j.kernel.impl.storemigration.StoreMigrator.needsMigration(StoreMigrator.java:135)
at org.neo4j.kernel.impl.storemigration.StoreUpgrader.getParticipantsEagerToMigrate(StoreUpgrader.java:268)
at org.neo4j.kernel.impl.storemigration.StoreUpgrader.migrateIfNeeded(StoreUpgrader.java:143)
at org.neo4j.kernel.impl.nioneo.xa.NeoStoreXaDataSource.start(NeoStoreXaDataSource.java:344)
... 25 more
org.neo4j.kernel.lifecycle.LifecycleException: Component 'org.neo4j.kernel.impl.transaction.XaDataSourceManager@6f8bb78d' was successfully initialized, but failed to start. Please see attached cause exception.
at org.neo4j.kernel.InternalAbstractGraphDatabase.run(InternalAbstractGraphDatabase.java:343)
at org.neo4j.kernel.EmbeddedGraphDatabase.<init>(EmbeddedGraphDatabase.java:59)
at org.neo4j.graphdb.factory.GraphDatabaseFactory$1.newDatabase(GraphDatabaseFactory.java:91)
at org.neo4j.graphdb.factory.GraphDatabaseBuilder.newGraphDatabase(GraphDatabaseBuilder.java:181)
at com.thingworx.system.GraphDatabaseServiceManager.initializeGraphDatabaseService(GraphDatabaseServiceManager.java:226)
at com.thingworx.system.GraphDatabaseServiceManager.initializeGraphDatabaseServiceManager(GraphDatabaseServiceManager.java:139)
at com.thingworx.system.GraphDatabaseServiceManager.getInstance(GraphDatabaseServiceManager.java:164)
at com.thingworx.system.ThingWorxBootstrapper.contextInitialized(ThingWorxBootstrapper.java:90)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4738)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5181)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:945)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1798)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.neo4j.kernel.lifecycle.LifecycleException: Component 'org.neo4j.kernel.impl.nioneo.xa.NeoStoreXaDataSource@361fb98f' was successfully initialized, but failed to start. Please see attached cause exception.
... 22 more
... 25 more
java.lang.RuntimeException: Error starting org.neo4j.kernel.EmbeddedGraphDatabase, D:\ThingworxStorage\database\.\data
at org.neo4j.kernel.InternalAbstractGraphDatabase.run(InternalAbstractGraphDatabase.java:366)
at org.apache.catalina.core.StandardContext.reload(StandardContext.java:3755)
at org.apache.catalina.manager.ManagerServlet.reload(ManagerServlet.java:1006)
at org.apache.catalina.manager.HTMLManagerServlet.reload(HTMLManagerServlet.java:614)
at org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:215)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:213)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:217)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:614)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:673)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1500)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1456)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Caused by: org.neo4j.kernel.lifecycle.LifecycleException: Component 'org.neo4j.kernel.impl.transaction.XaDataSourceManager@3108366d' was successfully initialized, but failed to start. Please see attached cause exception.
... 43 more
Caused by: org.neo4j.kernel.lifecycle.LifecycleException: Component 'org.neo4j.kernel.impl.nioneo.xa.NeoStoreXaDataSource@1119a6b1' was successfully initialized, but failed to start. Please see attached cause exception.
... 45 more
... 48 more
... 45 more
... 48 more
    Best answer by Aanjan
    Subrat, since it is a clean install, please stop Tomcat, delete the ThingworxStorage and BackupStorage folders and redeploy the war file. What are your ThingWorx, Tomcat and Java versions?
    Aanjan5-Regular MemberAnswer
    smishra11-VisitorAuthor
    Thanks.
    These 2 are in my D:\ root folder.
    Are they supposed to be there? Is it possible to change some config to put them somewhere else?
    Should I remove the content of these 2 folders or remove the 2 folders totally?
    The versions I have are:
    Tomcat v.8.0.20
    JDK 1.8.65
    ThingWorx 6.5
    Ah...I removed the folders. Undeployed and Deployed again. It works like a charm now.
    Thanks for your help.
