Query filter in "GenericThing" not working
  • May 16, 2017
  • 9 replies
  • 5576 views
Folks,
I'm trying to invoke a service and pass filter parameter in "GenericThing" template. The service returns all data ignoring the filter.  I need the service to return data based on filter parameter. Any help is appreciated. Here's my code for reference:
var filter = '{"filters": {"fieldName":"user_id","type":"EQ","value": "T1234"}}';
var params = {
    resourceProvider: "AdminUserProfileResourceProvider",
    serviceName: "GetUserProfiles",
    params: {
        dataShape: {
            fieldDefinitions: {
                query: {
                    baseType: "QUERY"
        rows: [{
            query: filter
// result: INFOTABLE
var result = Things["PTC.Resource.ResourceManager"].CallServiceOnProvider(params);
Thanks!
Pavan
Best answer by ankigupta
Hi Pavan Kumar Kodur​,
Could you please explain the requirement to apply the filter in JavaScript when you have already applied the filter in the Sql Query?
Just try to run following service in your generic Thing and you will get the desired result.
var params = {
    UserId: "A1234" /* STRING */
var result = Things["AdminUserProfileResourceProvider"].GetUserProfiles(params);
I hope it helps.
Per my understanding the single quote should not used in the query:
Try this
var filter = {"filters": {"fieldName":"user_id","type":"EQ","value": "T1234"}};
I hope it helps.
pkodur1-VisitorAuthor
Ankit Gupta,
Thank you for your response.
I tried changing the filter as per the suggestion. I still fetch all records. The issue still remains as "Filter" is not set.
The filter seems correct. Could you please CallServiceOnProvider Service; how is it applying the filter?
