Repeater selection causes scroll bars
  • February 11, 2016
  • 6 replies
  • 2942 views
I have a Layout with a Header and  a Row. I the Row i have a left side bar and a column.
I dropped a repeater in the left side bar. If i make it selectable and then either auto-select the first row or manually select a repeater item,
horizontal scroll bars show up in the left side bar.
Is there a way to prevent this?
Best answer by rtaylor-3
I went back and created a simple mashup and could not reproduce the behavior. It must be something specific to my mashup.
Sorry for the wasted cycles. I'll investigate more and if there is an issue, I will repost with hard evidence.
22-Sapphire I
February 12, 2016
Sounds like a bug, please submit with support.ptc.com
rtaylor-31-VisitorAuthorAnswer
I'm having a similar issue. Did you ever figure out what conditions cause the scroll bar? Thanks
