Responsiveness of a Repeater
Hi.
I've studied the several posts here regarding the repeater widget, but haven't found a clear guidance, yet.
The situation:
I have a responsive mashup that contains a repeater in a responsive layout. This repeater uses another responsive mashup which also only contains responsive layouts and elements (value display).
If I am using the defaults, the repeater visualizes the repeated mashup with a fixed height of 200. The setting for that is the FixedMashupHeight. According to the description it should only limit the height, if there is a value other than 0. My interpretation of that description is, that if the pre-requisites are met (responsiveness of mashup etc.) and the value is set to 0, that the repeater should adjust the height based on the visualized content of the included mashup.
But it doesn't: Any number is accepted to limit the height, but when using 0 it resets the height back to 200!
So up to now I haven't found a possibility to make the height of the repeated mashups responsive. Any ideas or help?
Many thanks.
Rayed
