REST API: How to get the multiple entries of a property while firing the URL?
  • May 30, 2016
  • 5 replies
  • 3773 views
I want to get the multiple entries of a properties by passing the URL.
For eg: When i pass the URL " ge2-****.cloud.thingworx.com/Thingworx/Things/Trucks/Properties?method=get&Accept=application/json "
I should get the following result:
{"iot":[                                      // When i fired, Its showing "rows", I want it to be "iot"
    "ID": "1",
    "TruckID": "T101",
    "PalletID": "P101",
    "TransitTime": "10:02:01",
    "CurrentLoc": "Kochi",
    "Health": "Good",
    "Source": "Trivandrum",
    "Destination": "Mumbai",
     "Shipper": "EY",
    "Remarks": "Asset valuable",
     "Action": "Action"
    "ID": "2",
    "TruckID": "T101",
    "PalletID": "P102",
    "Health": "Good",
     "Shipper": "EY",
     "Action": "Action"
Best answer by dmoon
I am not sure if I understood correctly or not, but I guess you might want to get properties with values for "Trucks" in your ThingWorx platform, not just from one truck, right?
If yes, you might have defined a thing template for trucks. Then you can get all implementing things with data from the thing template by using below rest api.
ge2-****.cloud.thingworx.com/Thingworx/ThingTemplates/PTC.Demo.Assets.MRIMachineTemplate/Services/GetImplementingThingsWithData?method=post&Accept=application/json
One thing you have to remember is that the "post" method is not enabled by default because of security issues. So if you want to execute services thru rest apis, please make "Allow Request Method Switch" enabled from the "PlatformSubsystem" in your composer.
Daniel
dmoon5-Regular MemberAnswer
Daniel
sv_011-VisitorAuthor
Thank you daniel!
I also tried getting using:
http://**-****.cloud.thingworx.com/Thingworx/Things/<Thingname>/Services/QueryPropertyHistory?method=post
I am getting the required output.
