Same Values Stream from different Things
  • May 4, 2017
  • 3 replies
  • 1822 views
Hi All,
I'm using a Thing A with properties logged on value stream SA.
I need to view the data of values stream SA from another Thing B.
I created a new Thing B and I assigned to this thing the value stream SA.
I used QueryPropertyHistory from Thing B but no value was returned.
Which can be the reason of that?
How can I view the data from values stream defined into Thing A from another Thing B ?.
Many Thanks
BR
Dimitri
Best answer by CarlesColl
Just to clarify, a ValueStream can contain data from various Things.
Hi Dimitri,
The only way to access a ValueStream data it's from Thing Property Owner, in your case Thing A. If you want to see the data from ThingB you should call with a custom service the QueryPropertyHistory on Thing A
May 4, 2017
Many Thanks Carles
Dimitri
