Service output InfoTable only returning maxItems 500 records
  • May 11, 2017
  • 11 replies
  • 6720 views
I am trying to use output of a service into another service, but I am only getting 500 records. When I run the same query in Oracle I get more records. Please let me know where and how can I set maxItems for output InfoTable to get full resultset.
Hemant
    Best answer by ankigupta
    Hi Hemant Rastogi​,
    I had posted regarding Sql Queries Service in this Thread above.
    Here it is for the quick reference:
    There is a property called Max Rows for the SQL (Query) service type which is defined on the Service info tab of the service and it has a default value of 500. You can change it according to your requirement.
    Hi Hemant Rastogi​,
    I hope it helps.
    For ThingWorx core Java/JavaScript services with output as Infotable; Max Rows property can be defined on the Mashup by clicking the Service and updating it in the Right Pane.
    11-Garnet
    May 15, 2017
    Hi Ankit, i have a requirement to limit the number of "Infotable" rows displayed using Grid in the Mashup. Like you mentioned above, is the "Max Rows" a property in Mashup that can be used?
    Hi Varunraj Shanmugavelayudham​,
    Yes, Max Rows can be used for ThingWorx core Java/JavaScript services with output as Infotable.
    hrastogi1-VisitorAuthor
    Ankit,
    Thanks for the response. My issue is I have created the service using SQL Query which is giving me output in a InfoTable. I am using the service in another service (JavaScript based) to manipulate the data.
    The issue is from SQL Query service, my InfoTable is being restricted to 500 maxitems records.
    Let me know if you have solution for this,.
    Hemant
    ankigupta5-Regular MemberAnswer
    Hi Hemant Rastogi​,
    Yes,. Thanks.
    Great! Could you please mark helpful and correct answers (if any) to close this Thread and let other members know that this Thread has a solution.
