setProperty method
  • November 2, 2015
  • 3 replies
  • 2917 views
Hello community,
I'm trying to figure out how does the property synchronization mechanism work.
I'm using TW 6.5 and the Java SDK.
If I understand well VALUE,TIME; QUALITY property is associated to each property update EVEN IF you don't specify them explicitly. I assume this because you can always invoke the "/Thingworx/Things/ThingName/PropertiesVTQ" REST API method on a Thing property.
In particular how does the setPropertyValue() method work?
I guessing this: setPropertyValue()  assumes currentTime taken at the invocation time of the setPropertyValue(), and it assumes quality GOOD.
Am I guessing right?
Giuliano
Best answer by mvonhasselbach
You're guessing right! The default value for the time is the currentTime when setProperty() is invoked, default for quality is GOOD.
A follow-up question: if you log a specific property in a Stream or ValueStream, is the "Quality" information logged ?
Giuliano
It should, by default. There is a service called GetPropertyQuality on both Streams and ValueStreams which gives you the quality values for a specific property.
