sigfox downlink
  • December 20, 2016
  • 5 replies
  • 4316 views
I am using Sigfox extension and it works fine for uplink.
I have read in documentation that downlink is not supported I don't really understand why :
I am using it simply outside Thingworx just by answering using a JSON message with the device ID and payload to send to sigfox when receiving a GET callback
(cgi-bin / python script)
exemple :{"FFFFF":{"downlinkData":"4142434441424344"}}
I am trying to use the "setDownlinkMessage" without success
I don't know what to put in "message" and "thingName" input, I tried many things but always (invalid payload in Sigfox logs)
Thanks for help
Pascal
Best answer by pjoly
solution given by support and working for me :
What is needed is to get results formatted as JSON. Two things are needed to make that happen:
  1. The service invoked needs to have the return basetype set as JSON.
  2. When you do the REST request (POST) to invoke the service you need to include the header: Accept: application/json. This can be included as a HTTP header or as an url parameter.
So, when you configure the downlink in Sigfox, you need to include this Accept=application/json in your url parameter.
Also, you may have to enable disable Filter Content-Type under PlatformSubsystem in TWX.
pjoly1-VisitorAuthor
In order to investigate, I have uploaded the extension into Eclipse java.
I cannot find any java code, just xml structures in the extension.
My question :
where can I find the code associated to  the POST request send by SIGFOX in order to put the right json message in the answer ?
https://myserver/Thingworx/Things/Sigfox.CallbackInterface/Services/CallbackDataBatch?appKey=mykey&batch={batch}
hello
nobody is using Sigfox with thingworx who could help me to fix this downlink issue or should I re-developp a new one ??
Is this extension developped by Sigfox or by Thingworx ?
Have you perhaps found a solution yet?
