Snippet to create an infotable from a datashape is not responding
  • November 29, 2017
  • 6 replies
  • 5316 views
Is there another way to get the code for a snippet and copy it into my script?  The snippet to create an infotable from a datashape is not responding when I try to move it over.
    Best answer by nmilleson
    var params = {
    infoTableName : "InfoTable",
    dataShapeName : "yourDataShape"
    // CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(logErrorAggregateShape)
    var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
    nmilleson17-PeridotAnswer
    var params = {
    Thanks!!  Not sure why some of them won't allow me to add to my script.  Maybe I'm due for upgrading to 8.1??
    I'm still on 8.0 and it works fine for me.  When you click the arrow button it should prompt you to select a DataShape.  Does it get that far?
    No it doesn't respond at all.  The position of my cursor in the script disappears and nothing happens.
