Special Characters in browser tabs
  • January 20, 2017
  • 2 replies
  • 2062 views
I am trying to get the following to work in my application.
The issue I am having is that the ® is being converted to %AE in the URL then the mashup fails to load because there isn't a mashup with the name Reflector%AE
Is there a way to actually make this work as I am hoping?
If I manually edit the browser and convert the %AE back to ® the mashup loads correctly.
Best answer by jkaczynski
Hello Paul Baierl​,
As you probably noticed, it's not recommended to use such special characters in the names of entities at all.
Just to test it, I've created a mashup with the trademark sign in the name. If I replaced the trademark sign with '%25C2%25AE', the URL is working.
OOTB Thingworx redirection (e.g. via Navigation widget) are working fine by default.
J.
Hello Paul Baierl​,
J.
pbaierl1-VisitorAuthor
Thanks for getting back to me Jakub.
Yes, I realize this isn't recommended.  I was asked if it was possible and wanted to make sure I had all of the information before reporting back to the project manager.
Thanks again,
Paul
