The Thingworx system filters garbage data, There is no good plan?
  • June 22, 2017
  • 4 replies
  • 2523 views
Hello, everyone.
     We collect a lot of useless data when we get data from the device side,Is there a good way to filter out the garbage data?
     I'm using data collected from the Java SDK!
Best answer by liliu
Hi Mr. Guo,
Using QueryPropertyHistory will return duplicate records. It's doesn't means we logged it.
As I know, the values stream doing regords, would follow DataChange Type in the property settings.
Best Regards,
Lily
Hi Ju Bin Liang​,
Can you please share your use case in more detail.
In Java SDK you can update code to send only requisite data.
In ThingWorx; you can add query in your Service to retrieve the filtered data.
Hi Mr. Guo,
May I know what kind of garbage data do you received? (Value stream? DataTable?)
Best Regards,
Lily
lliangjb1-VisitorAuthor
hi,Lily
     I want to filter the data before it goes to thingworx
liliu5-Regular MemberAnswer
Hi Mr. Guo,
Best Regards,
Lily
