ThingTemplate Service Calls - Things[ThingName] is not running
I have a problem with calling services from a thing that uses a particular ThingTemplate.
I am creating the Thing programmatically:
var params = {
thingTemplateName: equipmentTemplate,
description: description,
Resources["EntityServices"].CreateThing(params);
Things[equipmentName].EnableThing();
Things[equipmentName].RestartThing();
Which works fine, but when I try to call a service from that Thing:
Things[equipmentName].AddVisibilityPermission(params);
Then it throws a Things[equipmentName] is not running error.
This only happens when using one particular ThingTemplate as the 'equipmentTemplate', all other templates 'run' fine.
Does any one know why this might be happening? I can't find any permission issues, spelling errors or anything in that ThingTemplate. We did just upgrade to 6.5 - Would that have anything to do with this one ThingTemplate?
