Thingworx 6.6 PostgreSQL connection error
  • December 29, 2015
  • 6 replies
  • 4850 views
Anyone struggled with "Connections could not be acquired from the underlying database!" error after installing postgreSQL and trying to access Thingworx?
Best answer by avladescu
Removed "defaultValue": "twadmin" for the password element of the modelproviderconfig.json file which seems to have caused the error above and the access to Thingworx Composer was possible.
Full json file attached to the case http://internal.ptc.com/salesforce/attachments/cases/12/87/18/89/modelproviderconfig.json
avladescu1-VisitorAuthor
Changed a bit modelproviderconfig.json and now the error is "Improper value found for model provider configuration password, system cannot start without valid password"
avladescu1-VisitorAuthorAnswer
Can you give me the right modelproviderconfig.json version?
i can not use thingworx backend with postgres at the moment....
2016-01-22 17:57:35.072+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx Version Information
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] majorVersion = 6
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] minorVersion = 6
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] revision = 2
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] build = b148
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] schemaVersion = 809
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx System Environment Settings
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS: Linux
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS arch: amd64
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS version: 3.10.0-327.4.4.el7.x86_64
2016-01-22 17:57:35.073+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Total Processors: 2
2016-01-22 17:57:35.074+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default encoding: UTF-8
2016-01-22 17:57:35.074+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA vendor: Oracle Corporation
2016-01-22 17:57:35.074+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA version: 1.8.0_60
2016-01-22 17:57:35.074+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA install location: /usr/java/jdk1.8.0_60/jre
2016-01-22 17:57:35.074+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JVM Max Memory: 411 (MB)
2016-01-22 17:57:35.074+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-01-22 17:57:35.074+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp starting...
2016-01-22 17:57:40.661+0100 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] HA not configured. Initializing in standalone mode.
2016-01-22 17:57:40.661+0100 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Name = ThingworxPersistenceProvider
2016-01-22 17:57:40.661+0100 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Package Name = PostgresPersistenceProviderPackage
2016-01-22 17:57:40.682+0100 [L: INFO] [O: c.t.p.p.PostgresDatasource] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Reading configuration from configTableCol
2016-01-22 17:57:40.782+0100 [L: ERROR] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] [message: Improper value found for model provider configuration password, system cannot start without valid password]
2016-01-22 17:57:40.782+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Datastore database...INITIALIZED
