Thingworx 7.0.1 error while importing Windchill Extension 1.2.1-01
  • April 14, 2016
  • 4 replies
  • 2529 views
Hello Community,
While trying to import the ptc-windchill-extension-1.2.1-01.zip extension, I'm getting the following error:
     The extension 'ptc-creo-view-extension' version [10.2.30.38] must match the "major.minor.patch" pattern containing only integer values.
Appreciate any guidance.
Best regards,
Keiner
Here the error.log Outcome as reference:
2016-04-14 15:28:10.311-0600 [L: ERROR] [O: E.c.t.w.ExtensionPackageUploader] [I: ] [U: kmorales] [S: ] [T: http-nio-443-exec-6] [context: Extension Exception][message: The extension  'ptc-creo-view-extension'  version [10.2.30.38] must match the "major.minor.patch" pattern containing only integer values.] com.thingworx.extensibility.ExtensibilityException: The extension  'ptc-creo-view-extension'  version [10.2.30.38] must match the "major.minor.patch" pattern containing only integer values.
        at com.thingworx.extensibility.utils.ExtensionPackageUtilities.loadExtensionMetadata(ExtensionPackageUtilities.java:868) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.extensibility.utils.ExtensionPackageUtilities.extractExtensionPackages(ExtensionPackageUtilities.java:724) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.webservices.ExtensionPackageUploader.beginImport(ExtensionPackageUploader.java:174) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.webservices.ExtensionPackageUploader.service(ExtensionPackageUploader.java:103) ~[thingworx-platform-common-7.0.1-b482.jar:na]
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) [servlet-api.jar:na]
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) [catalina.jar:8.0.24]
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) [catalina.jar:8.0.24]
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.0.24]
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) [catalina.jar:8.0.24]
        at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:94) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:21) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:343) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:143) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:31) [thingworx-platform-common-7.0.1-b482.jar:na]
        at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:118) [thingworx-platform-common-7.0.1-b482.jar:na]
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219) [catalina.jar:8.0.24]
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) [catalina.jar:8.0.24]
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) [catalina.jar:8.0.24]
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142) [catalina.jar:8.0.24]
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) [catalina.jar:8.0.24]
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:617) [catalina.jar:8.0.24]
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) [catalina.jar:8.0.24]
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518) [catalina.jar:8.0.24]
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091) [tomcat-coyote.jar:8.0.24]
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668) [tomcat-coyote.jar:8.0.24]
Best answer by brue
As the message states, that extension's version does not match the major.minor.patch pattern. Remove the 38 from the packageVersion property in the extension's metadata.xml and you'll get past that error message.
brue1-VisitorAnswer
kmorales4-ParticipantAuthor
Thanks Brian. It worked perfectly.
Just FYI - Thingworx released new version of Windchill Extension whick works fine with Thingworx 7.0 and 7.1 (the issue is fixed).
