Thingworx Analytics: Send Data From Dataconnect To Analytics Server
  • February 20, 2017
  • 22 replies
  • 14255 views
I have just started with thingworx analytics 52.0 and DataConnect 52.0. I have some issues in sending data from dataconnect to analytics server.
I have followed these steps:
1] Set up Analytics Server
2] Import Analytics extension
3] Set up Dataconnect
4] Configure Platform Subsystem with dataconnect params
5] Configure MachineLearningAll thing with Analytics server params
6] Create a Data Analysis definition in TW and execute it
7] The zip file with property data and payload.json are being created in thingworx repository
8] Sending the zip(payload.json+csv) file to analytics server?
Step 8 is where I am facing problems. How to upload the created zip file to the analytics server? Do I have to use the service SubmitUploadDataset?
If so, then I am not able to test the service in Composer. When I Edit the UploadData field and try to add a row it tells me "Must have a datashape defined to add rows".
Am I approaching it the wrong way? Do I need to write a custom service to send the data?
I am having problems with understanding how exactly data from dataconnect is transfered to analytics server. I would appreciate any help on understanding this better and solving the issue.
Thanks & Regards,
Madhumita
Best answer by cmorfin
Hi Madhumita
I think you missed one step during the installation of DataConnect - see the DataConnect User's guide, chapter "Integrate ThingWorx and DataConnect"
you need to create a symbolic link between /repository and /ThingworxStorage/repository: ln -s /ThingworxStorage/repository /repository .
Hope this helps
Kind regards
Christophe
Hi Madhumita
When all is configured ok, the step 8 is done automatically.
The flow is:
1) DAD collect logged data from ThingWorx
2) DAD send the data (as skinny csv file + payload.json) to DataConnect
3) DataConnect transform the data and create one single resulting csv file
4) DataConnect create a dataset inside ThingWorx Analytics Server with the resulting csv file loaded as data. The dataset created has got the same name as the DAD.
If you do not have a dataset created in ThingWorx Analytics, then you probably have a problem in the configuration or in the way data is collected by the DAD.
You should start by reviewing the DataConnect log files under /opt/dataconnect/logs.
Note that I am in the process of writing a blog on this specific topic. I am hoping to have it published by next week.
If you can wait, I think it would be a good reading to understand how things work.
If you need further help I would probably recommend to open a case to Technical Support, because that is a topic that may need more data to progress.
Kind regards
Christophe
Hi Christophe,
Thanks for the help.I will be opening a case for the same.Also looking forward to the blog.
Thanks & Regards,
Madhumita
Hi Madhumita
Just to let you know, I have published the blog at :
How to use DataConnect when sending property values from the ThingWorx platform to ThingWorx Analytics.
I hope you'll find it of interest
Kind regards
Christophe
