Thingworx Remote Access Client: Connection to TWX on AWS failed
Hi guys,
I'm working with the Thingworx Remote Access Client and I want to connect this with TWX which is running on AWS.
When I start a connection via the RemoteAccessClientLinker-Widget the RA-Client starts and try to connect and timed out after few secondes with the error message:
Unable to connect to Thingworx; ensure platform is available at <xxx.xxx.xxx.xxx:443> and that proxy settings are correct
Last week I try the same with a PTC-Hosted Thingworx and everything works fine. On my AWS hosted Thingworx it will not connect. Strangely it works fine with the old Remote Access Widgets.
server.xml (without all comments)
<?xml version="1.0" encoding="UTF-8"?>
<Server port="8005" shutdown="SHUTDOWN">
 <Listener className="org.apache.catalina.startup.VersionLoggerListener" />
 <Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
 <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
 <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
 <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
 <GlobalNamingResources>
 <Resource name="UserDatabase" auth="Container"
 type="org.apache.catalina.UserDatabase"
 description="User database that can be updated and saved"
 factory="org.apache.catalina.users.MemoryUserDatabaseFactory"
 pathname="conf/tomcat-users.xml" />
 </GlobalNamingResources>
 <Service name="Catalina">
<Connector port="8080"
 protocol="org.apache.coyote.http11.Http11NioProtocol"
 connectionTimeout="20000" />
<Connector port="443"
 maxThreads="150"
 SSLEnabled="true"
 scheme="https"
 secure="true"
 keystoreFile="${user.home}/8.5.41/conf/.keystore"
 keystorePass="KEYSTOREPASSWORD"
 clientAuth="false"
 sslProtocol="TLS" />
 <Engine name="Catalina" defaultHost="localhost">
 <Realm className="org.apache.catalina.realm.LockOutRealm">
 <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
 resourceName="UserDatabase"/>
 </Realm>
 <Host name="localhost" appBase="webapps"
 unpackWARs="true" autoDeploy="true">
 <Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs"
 prefix="localhost_access_log" suffix=".txt"
 pattern="%h %l %u %t &quot;%r&quot; %s %b" />
 </Host>
 </Engine>
 </Service>
</Server>
config.json (on EMS-side)
 "ws_servers": [{
 "host": "xxx.xxx.xxx.xxx",
 "port": 443
 "appKey": "xxxxxxxxxxxxxxxxxxxxx",
 "logger": {
 "level": "INFO",
 "publish_directory": "/microserver/logs",
 "publish_level": "INFO",
 "max_file_storage": 2000000,
 "auto_flush": true
 "http_server": {
 "ssl": false,
 "authenticate": false
 "ws_connection": {
 "encryption": "ssh"
 "certificates": {
 "validate": false,
 "allow_self_signed": true
 "tunnel": {
 "buffer_size": 8192,
 "read_timeout": 100,
 "idle_timeout": 300000,
 "max_concurrent": 4,
 "verbose": false,
 "duty_cycle": 100
 "file": {
 "max_file_size": 8000000000,
 "virtual_dirs": [
 {"other": "/microserver/other"},
 {"tw": "/microserver/tw"},
 {"updates": "/microserver/updates"}
 "staging_dir": "/microserver/staging"
 "auto_bind": [{
 "name": "EMSBox"
drichterAnswer
So, I think I fixed the problem. I add a domain to my ec2 where thingworx is running. Than I generate a certificate from lets encrypt for this domain. Now its look like the client can connect to thingworx. I'm not hundred percentage sure because I get a new error message in remote client:
Platform websocket error encountered. (error: Error: Hostname/IP doesn't match certificate's altnames: "IP: xxx.xxx.xxx.xxx is not in the cert's list: ")
xxx.xxx.xxx.xxx = IP of EC2.
Support
Hi @drichter.
Is the hosted ThingWorx instance the same version as that running in AWS?  Is the old Remote Access client running on the same machine?  This could be a firewall issue.
--Sharon
drichter1-VisitorAuthor
On AWS runs TWX 8.4.5-b102.
I try it with a other 8.4 Version (I'm not sure which exact version it was).
Actualy I use Version 8.5.0-b12.
I would rule out a firewall-problem, because with the old widget (with java starter stuff) works and this use port 443 too. And on AWS side port 443 is open.
drichter1-VisitorAuthorAnswer
