Thingworx self-signed certificate instructions not working
I followed the instructions as specified in Article - CS193947.
After booting up the server on localhost. My http connection worked but the my https connection gives me a ERR: No Response from server.
I am using the portable edition on local pc for demo purposes.
For the config.xml
I commented out
<Connector port="${port.https}" protocol="org.apache.coyote.http11.Http11NioProtocol"
maxThreads="150" SSLEnabled="true" scheme="https" secure="true"
keystoreFile=".keystore" keystorePass="${https.keystorePassword}"
clientAuth="false" sslProtocol="TLS" />
And added
SSLEnabled="true" maxThreads="200" scheme="https" secure="true"
defaultSSLHostConfigName="Full Computer name as FQDN">
<SSLHostConfig hostName="Full Computer name as FQDN" sslProtocol="TLS">
<Certificate certificateKeystoreFile="keystore.pbx"
certificateKeystorePassword="Password0" certificateKeystoreType="PKCS12" />
</SSLHostConfig>
</Connector>
Attached is the original xml file (server.xml) that I made the changes to (Which works).
The server copy i'm trying to use with the removed is servernew.xml (Which only works for http, I removed FQDN and password in the attachment)
I didn't make any changes to any other config files and I have the generated keystore.pbx next to the original .keystore in the folder.
Any idea what is going wrong here?
I do what to get it signed by CA but as I understand it, this is the first step that must be completed.
slangleyAnswer
Support
Hi @AT_10013510
I'm not sure your keystore is in the correct format.  Give these instructions a try.
--Sharon
22-Sapphire I
Check if you have your https port 443 or 8443 enabled in your server.xml 443 would be default
check this article as an example: https://community.ptc.com/t5/ThingWorx-Developers/SSL-certificate-issues/m-p/634390#M40333
Hi Pai,
Yes I did have it enabled in the config. The port used was 8443. The server.xml was a working https config that I was using (Default with Thingworx portable).
I could navigate to the https://<FQDN>/ and it would work. When changing out to a new certificate following the article instructions It fails on the 8443 port.
I used the commented out code in the server.xml section as the basis and made the addition of
</SSLHostConfig>
</Connector>
Where port.https in the config is set to 8443 like in the original configuration which worked.
slangleyCommunity ManagerAnswer
Support
Hi @AT_10013510
--Sharon
