To find dotnet SDK version
  • March 27, 2017
  • 7 replies
  • 4019 views
Hi Team,
We have downloaded dot net SDK assemblies from thingworx market place and forgot the version that we have downloaded but started using thingworx-dotnet-common.dll.
So is there anyway to find out to which version this file belongs like SDK 5.0 or 5.6 like that?
Best answer by tkawasaki
You're right. I just downloaded old versions by myself and checked Details tab.
I'm not sure if the information below helps your situation but you might be able to guess the version you're using from "Data modified" information in the Details tab.
  • ThingWorx-DotNet-SDK-5-0-1-103 : "Date modified" in the Details tab shows "2014/06/20 13:59"
  • ThingWorx-DotNet-SDK-5-5  : "Date modified" in the Details tab shows "2015/03/31 16:47"
  • DotNet-SDK-5-6-0-549  : "Date modified" in the Details tab shows "2015/09/17 23:24"
It appears that DotNet SDK newer than DotNet-SDK-5-6-0-549 has correct version information in Details tab.
20-Turquoise
March 27, 2017
You should have a "version" text file within your SDK downloadable.
I understand your inputs Polina. But we lost the folder from where we took the thingworx-dotnet-common.dll and have no reference to that version.txt.
All we have is thingworx-dotnet-common.dll referred in our SDK. So just wanted to understand, if there is a way to find out the version from thingworx-dotnet-common.dll by running any command/script?
You can see the version info in the Details tab of the file property.
1. Click right mouse button on the thingworx-dotnet-common.dll and select Properties
2. Select detail tab in the property window
3. Product version(File version too) tells which version you're using
Takaaki
