Trouble for export with UTF8 format
  • December 12, 2016
  • 5 replies
  • 3956 views
Hello everyone,
I got a trouble with a file I want to import. I got this error message.
The most disturbing thing is that I made an export from 6.5 to 7.1.4, without no modification, so it should be that simple.
I tried to add the java options "​-Dfile.encoding=UTF-8​" and even to save the XML in different type of UTF-8, still doesn't work.
Have you a idea how I could solve it ?
Quentin
Best answer by QuentinR
Well, I actually succeed in making it work.
I just change manually in the XML file the number of the version, minor version. And it worked, strange but it worked.
EDIT: actually, it is due to the xml export format. To avoid it, do an export to binary (.twx format).
Quentin
Hi Quentin Riviere​, Just to confirm, was the tomcat restarted after making the changes?
QuentinR14-AlexandriteAuthor
Hello Gupta,
Yes, I confirm I restarted the tomcat, I even restarted the computer to be sure.
Quentin
i am facing similar issue how i dont have XML back nly have binary format.. Can u please Suggest how to Change the format frm Binary to Xml or such Kind.
I don't know how to turn a Binary to a XML. It's only when exporting that you can select the format.
Actually, it's strange that you have a UTF8 trouble with the binary .twx file. Did you open it in a text editor (Notepad++) and saved it?
Best regards,
Quentin
