Unable to delete thing from Composer
  • September 5, 2017
  • 2 replies
  • 1513 views
Hi Everyone,
I am unable to delete thing from thingworx composer, It is showing the following error
Unable to remove thing from database: [DemoThing] [1,018] Data store unknown error: [Error occurred while accessing the property provider.]
Can anyone one got this problem, how it can be solved..??
Madhu
Madhu Nalla​: Have you created DemoThing using scripts?? Can you do a tomcat restart and try deleting the Thing again and check if it works.
-Durgesh
Madhu Nalla​ - This seems to be related to Database connection only .What is the database you are using ? Also is your DB on the same server as on Thingworx or it's external ? you can also try with tomcat restart as mentioned in the above reply .
Mukul Narang
