May 23, 2024 5:52 AM UTC
"Unable To Parse JSON Request" in Application logs while executing the below code from mashup
Iam continously getting error: "Unable To Parse JSON Request" in Application logs while executing the below code from mashup but the code providing results successfully while executing directly from Service. Kindly tell me what is the problem in below code.
The code is:
try{
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    infoTableName: "InfoTable",
    dataShapeName: "FabShopIntake.ScheduleTasks-DS"
if(editedTable===true){ Users[CurrentUser].SheetMetal_ScheduleTasks = editedTable;}
else if(AssignedToGroup === true)
            result = griddata;
else{
    result.AddRow({
        Select : true,
        GroupName : "LASER CUTTER Group",
        Order : 1
    result.AddRow({
        Select : true,
        GroupName : "BEND-WELD-SEC OP Group",
        Order : 2
    result.AddRow({
        Select : true,
        GroupName : "PAINT Group",
        Order : 3
    result.AddRow({
        Select : true,
        GroupName : "SHIPPING Group",
        Order : 4
}catch(err){
logger.warn("SheetMetalScheduleGroups: error is "+err);
May 23, 2024 8:17 AM UTC
More about this error:
May 23, 2024 8:44 AM UTC
I tried all of the above. Still it is not working.
May 23, 2024 10:36 AM UTC
I copied the code and added the input params "editedTable" (BOOLEAN) and "AssignedToGroup" (BOOLEAN). I also created a datashape with the same columns as you (but different entity name).
The service is running just fine.
I can only suspect that the "griddata" variable (which seems to be also an input parameter) is invalid somehow. Comment out the "if" cases one by one and see were it throws the error.
May 23, 2024 11:16 AM UTC
Yes when iam including griddata infotable, then iam getting this error.
griddata is a infotable datatype created as one of the field definitions in datatable.
Iam passing this field value from grid to service in mashup.
May 23, 2024 1:08 PM UTC
Then I think that the "gridData" does not have the correct format or is not a valid infotable in some sense. Can you log the "gridData" variable in the ScriptLog and post it here?
logger.warn(JSON.stringify(gridData));
Rocko
May 27, 2024 6:36 AM UTC
"result" variable type is Infotable, but griddata type is JSON.
I don't see a conversion in the code?
Emeritus
May 30, 2024 8:04 AM UTC
Hello @AP_10343008,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
May 30, 2024 2:39 PM UTC
I added default empty row in the datashape of infotable type column present in datatable. It made the service execute when there is no value present in the particular column.
