What is the correct syntax for specifying multiple parameters in the url for a FileResource in a client side widget?
I get the above error when trying to add the drawing library to a modified GoogleExtensions widget:
<FileResource type="JS" url="https://maps.googleapis.com/maps/api/js?key=MY_KEY&libraries=drawing" description="" isDevelopment="false" isRuntime="true" />
I've also tried:
In this case, the extension gets imported fine, but then it the drawing library is not really loaded.
Thanks!
Cletus
