What operating systems can I use for a VNC connection with ThingWorx?
  • January 18, 2017
  • 4 replies
  • 2608 views
Hi all,
I'm using the Remote Access Widget to connect to remote things using ThingWorx through VNC. Regarding the client side of the VNC connection (so where I open the ThingWorx web interface where there is the widget), can I use it with any OS or is it compatible only with Windows OS?
Best answer by PaiChung
The Remote Access Widget uses a Java Applet so that has to be able to run.
Now you can set it up to use a Browser based Client for VNC then that requirement goes away and but you will need to make sure your browser supports the VNC Client 'plugin'
PaiChung22-Sapphire IAnswer
22-Sapphire I
January 18, 2017
Are you meaning the Guacamole Plugin Extension available in the Marketplace or the Web Socket Tunnel Widget?
22-Sapphire I
January 18, 2017
Guac I believe would require it to be installed on the target machine/device
I was actually thinking of something like noVNC
We used to have an extension for this, but it looks like that is no longer in the marketplace, it may be included with Thingworx Utilities
