What's the correct way of using the /Thingworx/Importer API resource?
  • February 24, 2017
  • 3 replies
  • 3043 views
I thought I could sneakily work out how to use this by using Firebug to look at the request made via Composer, but I always get an error in the Application log that says:
Forbidden file upload from https://x.x.x.x:y/Thingworx/Importer
(address redacted)
The curl command I have been trying to use to upload XML for a single (if that makes a difference) entity is:
curl --user 'Administrator:xxx' -F 'file=@entity.xml' 'https://x.x.x.x:y/Thingworx/Importer?purpose=import&usedefaultdataprovider=false&WithSubsystems=false'
(address and password redacted; and I've slightly simplified this curl request but only to omit --insecure because I'm using a self-signed certificate)
Where is this wrong...?  Shouldn't I even be using the resource in this way?
Best answer by posipova
This is the certain value I meant: TWX-XSRF-TOKEN-VALUE.
Glad it works now.
20-Turquoise
February 24, 2017
Hi Richard, the error indicates that the csrf header must equal a certain value, and be included in the command.
rwiseman1-VisitorAuthor
Thanks Polina, although could you elaborate on what "a certain value" means please?
Interestingly, the curl command that Firebug creates from the request Firefox made does not include a csrf header.  It does, however contain a header with "XSRF" in it: "X-XSRF-TOKEN: TWX-XSRF-TOKEN-VALUE"
If I add this header, the request succeeds.
posipova20-TurquoiseAnswer
20-Turquoise
February 27, 2017
Glad it works now.
