Where to find best practices for Tomcat Security Manager?
In the Tomcat Security Considerations it's recommended to start Tomcat with the Security Manager.
However, when I startup Tomcat with the security option I get an error containing 'java.security.AccessControlException: access denied ("java.lang.RuntimePermission" "modifyThread")' when trying to read the platform-settings.json.
Are there any templates / best practices for how to configure the catalina.policy file with the ThingWorx webapp?
18-Opal
Hello @mneumann,
Cool, I thought that Security Managers died together with applets a decade ago 🙂
I think the biggest problem with your empirical fine-grain approach (without using wildcards) is that you'll never really know if you've already identified all issues or not yet (it's an NP-complete problem after all). This alone should prevent you from attempting it for any practical purposes.
I wonder if there's any business requirement behind this (Co-hosting ThingWorx with other webapps? Allowing users to load their own custom extensions?)
As for the settings related to filesystem access (the only reasonable SM use case really) I guess that simply restricting Tomcat user access on your *nix box is enough (and probably more reliable as well, given that Tomcat and/or JVM may contain their own bugs and vulnerabilities).
Constantine
raluca_edu
Hi Michael,
I did not tested it, but please check this link, where it is explained some configuration for Tomcat Security Manager.
You probably need to add a line " permission java.io.FilePermission "${thingworx.home}${file.separator}-", "read,write";"   where thingworx.home will be an environment variable that has the path to the folder containing the platform-settings.json.
Hope it helps,
Raluca Edu
PS. Nice hearing from you!!!! 🙂
mneumann16-PearlAuthor
Hi Raluca!
Nice hearing from you as well 🙂
The link was quite helpful and I have found similar sites as well.
I managed to move on to various other errors. At the moment I'm stumbling from error into error with granting the permissions on a proper level. So far I've struggled up to the point where I defined these:
grant codeBase "file:${catalina.base}/webapps/Thingworx/-" {
 permission java.io.FilePermission "/ThingworxPlatform/-", "read, write";
 permission java.io.FilePermission "/ThingworxStorage/-", "read, write, delete";
 permission java.io.FilePermission "/ThingworxBackupStorage/-", "read, write, delete";
 permission java.io.FilePermission "/ThingworxSourceControl/-", "read, write, delete";
 permission java.lang.RuntimePermission "getenv.THINGWORX_PLATFORM_SETTINGS";
 permission java.lang.RuntimePermission "modifyThread";
 permission java.util.PropertyPermission "com.fasterxml.jackson.core.util.BufferRecyclers.trackReusableBuffers", "read";
 // This needs to be removed and replaced with proper permission management
 // permission java.security.AllPermission;
I'm a bit concerned about having to go through hundreds of exceptions to get it running - while not being sure, if I captured all of the required permissions in the end. The good thing so far is, that Tomcat is nice enough to tell exactly which class / permission is missing.
I could just run the AllPermissions - but that would be the same like not having the SecurityManager at all.
18-Opal
Hello @mneumann,
Constantine
