while using windchill info*engine tasks to establish connection with thingworx i got the following error..?
please convey your suggestions.
Error executing service
Wrapped com.ptc.jws.service.com.ptc.windchill.ws.Exception_Exception: com.infoengine.util.IEException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting; nested exception is: wt.util.WTException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Cause: com.infoengine.util.IEException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting; nested exception is: wt.util.WTException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting
regards,
madhu
