Why I can not use 'return' keyword to stop script execution?
  • December 20, 2017
  • 2 replies
  • 1923 views
Why I can not use 'return' keyword to stop script execution? It should be supported in a javascript function.
Best answer by CarlesColl
It's how it works, to return a value you should use var result = "value";
If you want to execute script execution anyway you can use break and block combination:
end: {
// Your code here
// if you want to break here: break end;
//  More code here
end: {
// Your code here
//  More code here
zhuwenxi12-AmethystAuthor
It works perfertly. Thanks for your information.
